996p2 freescan question
ryradio
#1
Im using a new 996p2 with freescan and the rr subscription. I was able to import my counties P25 system from RR.
Is the import plug and play or do I have to manually configure any settings in my new system/groups besides assigning keys to them?
ryradio
#3
Another question I have....
with freescan the alpha tags are in the "display" column.... however sometimes when a channel pops up on the scanner I am getting an ID number displayed on the scanner....
First row would be the P25 site as I named it
second shows ID: then the number
how do I toggle this so I see an alpha tag instead?
Anne Arundel County, MD
#6
This is correct. You are in search mode and those items coming up with just an ID number are talkgroups that you do not have programmed.
536/436/HP1/HP2/996XT/996P2/396XT/325P2/PSR800
ryradio
#7
thank you.... I was unclear about the difference of scan/search... now that makes sense to me. I will test today.
