996XT CC Noise on some broadcasts
Markscan
New Jersey
Do you have the P25 talkgroups set to digital only? That sounds like it may be the problem.
webstar22
Earth Sector 001
I don't see a setting to change the talkgroups to digital.
I see TGID Name, TGID Decimal, Number tag, priority, Alert tone, Alert level, Alert Colour, Alert light and record.
And no setting for the site or the system either.
Markscan
New Jersey
You need to :program system- edit group-select group-edit channel-then set audio type. Set all P-25 talkgroups to digital only. This may be the problem.
