I'm considering purchasing a Compactenna scanner antenna and have a couple of questions.
I've read the posts here a couple of people mentioned mounting the antenna on a metal filing cabinet using a NMO mag mount. I know it's also mentioned somewhere in the company literature. Does it really work well that way? I know that there is a large YMMV factor, but I'd appreciate some opinions.
Depending on how well that works, I might do some swapping around and mount it on my truck. I've seen references to moisture and not removing the antenna. Since I'll have to take my truck to the car wash and will definitely want remove the antenna as I do now, can someone comment on that issue, if there is one?
