A little DMR help PLEASE
mgf
#1
What am I missing? I purchased the DMR key. Updated everything. Created a 3 new favorites list..1 Westerville City Schools…2 Columbus Ham DMR…3 Ohio Health – Central Ohio. Enabled correct service types and tried 3 different antennas…So far not 1 transmission has been received.
RakkFO
Centeral Ohio
#2
Send me your code plug RakkFO@gmail.com
We could go back and forth with check this and check that, each round will take 8 hours.
How do you have them programmed? Off top of my head I think I have Ham programed as single site.
If you park your scanner on W8TRB 145.370 or 443.150 do you get any decode?
mgf
#3
RakkFO thanks for the quick response.
I am a little under educated here. I do not know what a code plug is.
All I did was go in to Sentinal clicked on each of the above and created 3 new favorite lists. I have had it on Westerville City Schools for about 2 hours with nothing at all. Before the switch to DMR (Last school year) I was able to hear the school and some buses most of the day.
hiegtx
Dallas, TX
#4
He's referring to your Favorites lists.
Export them into *.hpe files, then email. He can then load them and see what needs to be done.
File->Export to *.hpe on the menu in Sentinel.
RakkFO
Centeral Ohio
#5
Sorry I did not even think about the terminology.
Let's start small. What scanner do you have?
mgf
#6
RaKKFO - (436) Just emailed you a file..Thanks
hietx - Thanks for the explanation
RakkFO
Centeral Ohio
#7
It just occurred to me that if you are using Sentinel you must have a x36 series radio.
Go to settings then upgrade and DMR and let me know what you see
RakkFO
Centeral Ohio
#10
Ok so the ID: Search is set to off. Since there is no talk group id's programed the radio is searching for a known talkgroup but there are none.
Try setting ID: Search to on and let me know if there is any change. There is an icon with a star and pencil over top of it. Click that and the favorite list your DMR list is in, you should see ID: search. Double click on off and change to on.
mgf
#11
I had it switched to ON eariler today, then turned it off. It's back on now (All 3 DMR Favorites)...Not a peep so far.
RakkFO
Centeral Ohio
#12
Ok so program the frequencies as a conventional system to see if you get any hits. Try the Columbus amateur radio DMR repeater first.
Maybe you are not in range? Have you ever decoded DMR?
mgf
#13
I will have to do some searching / reading to try and figure out how to create a conventional system….I’ll keep you posted on the progress…Thanks again.
RakkFO
Centeral Ohio
#15
I will program my scanner with your data. When I go to Columbus I will scan and see if I get anything.
mgf
#17
RakkFO – Thanks for all of the help. I have it working (somewhat) now.
W8RMH – I was reading about that yesterday and plan on giving it a try today.
RakkFO
Centeral Ohio
#18
So now you have it decoding you can hand program the TGID and see if that helps.
On the bottom right of your screen does it say CON or CON+
RakkFO
Centeral Ohio
#19
Also remember to submit the data you discover so the next person that wants to listen does not have to do all this work again please.
mgf
#20
Just saw a tranmission on 460.2875 Color 13....Bottom right of screen was XTP
