A little DMR help PLEASE
mgf
What am I missing? I purchased the DMR key. Updated everything. Created a 3 new favorites list..1 Westerville City Schools…2 Columbus Ham DMR…3 Ohio Health – Central Ohio. Enabled correct service types and tried 3 different antennas…So far not 1 transmission has been received.
RakkFO
Central ohio
Send me your code plug RakkFO@gmail.com
We could go back and forth with check this and check that, each round will take 8 hours.
How do you have them programmed? Off top of my head I think I have Ham programed as single site.
If you park your scanner on W8TRB 145.370 or 443.150 do you get any decode?
mgf
RakkFO thanks for the quick response.
I am a little under educated here. I do not know what a code plug is.
All I did was go in to Sentinal clicked on each of the above and created 3 new favorite lists. I have had it on Westerville City Schools for about 2 hours with nothing at all. Before the switch to DMR (Last school year) I was able to hear the school and some buses most of the day.
hiegtx
Mentor
Dallas, TX
He's referring to your Favorites lists.
Export them into *.hpe files, then email. He can then load them and see what needs to be done.
File->Export to *.hpe on the menu in Sentinel.
RakkFO
Central ohio
Sorry I did not even think about the terminology.
Let's start small. What scanner do you have?
mgf
RaKKFO - (436) Just emailed you a file..Thanks
hietx - Thanks for the explanation
RakkFO
Central ohio
It just occurred to me that if you are using Sentinel you must have a x36 series radio.
Go to settings then upgrade and DMR and let me know what you see
mgf
DMR/MotoTRBO has already been activated.
RakkFO
Central ohio
Ok so the ID: Search is set to off. Since there is no talk group id's programed the radio is searching for a known talkgroup but there are none.
Try setting ID: Search to on and let me know if there is any change. There is an icon with a star and pencil over top of it. Click that and the favorite list your DMR list is in, you should see ID: search. Double click on off and change to on.
mgf
I had it switched to ON eariler today, then turned it off. It's back on now (All 3 DMR Favorites)...Not a peep so far.
RakkFO
Central ohio
Ok so program the frequencies as a conventional system to see if you get any hits. Try the Columbus amateur radio DMR repeater first.
Maybe you are not in range? Have you ever decoded DMR?
mgf
I will have to do some searching / reading to try and figure out how to create a conventional system….I’ll keep you posted on the progress…Thanks again.
RakkFO
Central ohio
Found here: http://info.uniden.com/twiki/bin/view/UnidenMan4/DigitalMobileRadioUpgrade
RakkFO
Central ohio
I will program my scanner with your data. When I go to Columbus I will scan and see if I get anything.
mgf
RakkFO – Thanks for all of the help. I have it working (somewhat) now.
W8RMH – I was reading about that yesterday and plan on giving it a try today.
RakkFO
Central ohio
So now you have it decoding you can hand program the TGID and see if that helps.
On the bottom right of your screen does it say CON or CON+
RakkFO
Central ohio
Also remember to submit the data you discover so the next person that wants to listen does not have to do all this work again please.
mgf
Just saw a tranmission on 460.2875 Color 13....Bottom right of screen was XTP
