Afoot
- Joined
- Jan 18, 2020
- Messages
- 13
You're sitting on a Tier III control channel. It may not carry much voice traffic. Monitor the voice channels instead. And you can't properly monitor a trunking system with SDR# anyway...
Yes, I have SDR Console 3, and I have 2 dongles, but could you explain to me what you say explained for clumsy? Please!You may want to try SDR Console 3 - If you have two dongles it has DSD+ built in and it will follow trunks if you can find the control channel.
Built in? So no DSD+ required?You may want to try SDR Console 3 - If you have two dongles it has DSD+ built in and it will follow trunks if you can find the control channel.
The instruction are in the program they are pretty simple
Thanks again for your patience. This inexperience joins my English, which is disastrous, I am Spanish Thank you.
What I have not learned yet is to be able to configure the two dongles in the same program. I always get one ...
You are a saint, thank you. I will try again, but I think he does not recognize me ... However I leave again another image of how I read the DRM well and do not listen. And it is not that I have misconfigured the audio output, because others listen to them. Thank you.View attachment 79291
Then why does the DSD+ console window show it decoding the DMR control perfectly?In your screenshot the Bandwidth is not 40kMz - in this set up it needs to be or it won't decode
Hello again, I think that should not be the culprit that I can not hear. Here is the image if I set to 40 or 48, now it gives error in the signals that I could decode. I think that I cannot listen to the others because they are coded so that they cannot be heard.In your screenshot the Bandwidth is not 40kMz - in this set up it needs to be or it won't decode
Did you see that the software recognized a second dongle when you started up? Without a second dongle it cannot follow a trunk although it will decode straight DMR with one dongleHello again, I think that should not be the culprit that I can not hear. Here is the image if I set to 40 or 48, now it gives error in the signals that I could decode. I think that I cannot listen to the others because they are coded so that they cannot be heard.
