A Question About Bluetooth
Lancaster County PA
#1
I like to listen to the G5 in private. In fact my wife prefers it. Especially close to bed time.
I have a cheap Bluetooth receiver/transmitter with a set of ear buds hooked into it. It connects and receives easily, but to be honest what I am listening to sounds bad. The speaker on the G5 sounds much better.
My question.....Like I said I know I am using a cheap little contraption to use the Bluetooth option. Does anyone out there have a recommendation for a better sounding device that actually works with the G5? I don't want this to be a trial and error thing with different devices. That can get expensive. Or do the more expensive options still sound how should I say......terrible?
Scottsdale, AZ - Beat 17
#3
Use the Search Box
Bluetooth for Unication has been addressed ad nauseam (that means a lot...) on this site.
Use the search box at the top of this page to obtain and review all of the discussions.
#4
I agree that your earbuds are the more likely problem with your low fidelity, not the BT receiver/transmitter.
DanRollman
Atlanta, GA
#5
Use the Search Box
I apologize in advance if I am overlooking it (I'm sure I am) but after some searching I am not readily seeing discussion of the Unication-branded bluetooth headset found at places like Unication T81G1DHQ65P-R Bluetooth Headset - G-Series. Has anyone here tried this one?
Dan
NebraskaCoder
Omaha, NE
#6
I haven't but I can say as a beta tester, I no longer hear any beeps. Not sure if it is the beta firmware I'm using or if it is a newer G5 (not beta related) that got rid of the beep.
Sent from my SM-G965U using Tapatalk
N6ML
SF Bay / Delta, CA
#8
The BlueTooth implementation in the V1.20 firmware (currently in beta) is significantly different, and does eliminate the beeps on several devices that I've tried it with.
Danny37
New York City
#10
Any word on when this beta firmware will be released to the public? If so, I'll probably bite the bullet and buy one if they fixed the Bluetooth issue.
#19
Be sure to turn off blue tooth before you go to sleep. 8 hours of 2.4Ghz exposure to RF that close to your body doesn't bode well in terms of biological effects. Yes, it's documented...
