DSDPlus A question about how to configure additional freqs/systems
bobruzzo
W1AV
Cranston, Rhode Island
OK so now that I have things running ok I want to move ahead and ADD a few more frequencies to monitor. But there are a few editable files to do this which is confusing and I dont know which one(s) to use. I appears to be the "DSD Plus siteloaders file" I copied/pasted from RR database the P25 system I am listening to into the siteloader file. Attached is an NXDN 48 system I would also like to be able to monitor. But I don't know how to add NXDN and if I can include the data in the same file as the P25 system. I DID persuse those .txt files for help but there is way too much information for me to make sense out of. So would I have to make a NEW separate file to monitor this NXDN system or can I just include it in the same place I put my P25 system data? I couldn't find any sample text lines for NXDN so not sure how to actually type the data in so it will work. I was able to find the switch "-fa" to enable the monitoring of everything. But dont know if I need to use it or where to paste it. So what I am trying to say is how do you ADD other things to monitor to the existing setup? In RR there are no "pre defined report" to download and put in DSD Plus for this NXDN system. It looks like the data has to be entered THIS way: NXDN48, 51, 001 "Cranston"
BM82557
Berkeley Co WV
Here's an example of part of my siteloader file --
DMR,0123,1,"Maryland Correctional Training Center Hagerstown MD"
DMR,4567,1,"Maryland Correctional Institution Hagerstown MD"
DMR,8910,1,"Roxbury Correctional Institution Hagerstown MD"
DMR,0001,1,"Loudoun County Schools Transportation East"
DMR,0002,1,"Loudoun County Schools Transportation East"
DMR,0003,1,"Loudoun County Schools Transportation west"
DMR,0004,1,"Loudoun County Schools Transportation Central and West"
DMR,0005,1,"Loudoun County Schools Transportation Central and West"
DMR,0006,1,"Loudoun County Schools Transportation Central and West"
DMR,0007,1,"Loudoun County Schools Transportation Central and West"
DMR,0008,1,"Loudoun County Schools Transportation Field Trips"
DMR,0009,1,"Loudoun County Schools Transportation Field Trips"
DMR,0010,1,"Loudoun County Schools Transportation Field Trips"
DMR,0011,1,"Loudoun County Schools Transportation Field Trips"
DMR,0012,1,"Loudoun County Schools Transportation Field Trips"
DMR,0013,1,"Loudoun County Schools Transportation Maintenance"
DMR,0014,1,"Loudoun County Schools Transportation Maintenance"
DMR,0015,1,"Loudoun County Schools Transportation West"
DMR,0016,1,"Loudoun County Schools Security"
DMR,2324,1,"Thurmont MD 145.1700 DMR Repeater Frederick County"
DMR,2526,1,"Thurmont MD 147.1950 DMR Repeater 2 Frederick County"
TIII, 1, 1.2,"Site 21763125"
TIII, 1, 2.4,"Site 21753125"
TIII, 1, 3.1,"Site 21751875"
Cap+,7035,1,"CAP+ Virginia Fredericksburg"
Cap+,7035,2,"CAP+ Virginia Independent Hill"
Cap+,7035,3,"CAP+ Virginia King George"
Cap+,7035,4,"CAP+ Virginia Linden"
Cap+,9818,1,"Chambersburg Area School District"
Cap+,8888,1,"Site 1 Cap+ Procter and Gamble System"
Cap+,8888,2,"Site 2 Cap+ Procter and Gamble System"
NXDN48,428,1,"Meritus Medical Center Hagerstown MD"
Con+,0141,1,"MADRN Harrisburg North Dauphin County"
Con+,0141,2,"MADRN Cornwall Lancaster County"
Con+,0141,4,"MADRN York Site York County"
Con+,0141,6,"MADRN New Holland Lancaster County"
Con+,0141,7,"MADRN New Cumberland York County"
Con+,0141,8,"MADRN Hanover York County"
Con+,0141,9,"MADRN Shippensburg Franklin County"
Con+,0141,11,"MADRN Rawlinsville Lancaster County"
Con+,0141,15,"MADRN Reading Berks County"
Con+,0141,17,"MADRN Red Lion York County"
Con+,0141,22,"MADRN Lancaster City Lancaster County"
Con+,0141,23,"MADRN Newport Perry County"
Con+,0141,31,"MADRN Site 31"
Con+,0141,41,"MADRN Dupont Luzerne County"
Con+,0141,43,"MADRN Waynesboro Franklin County"
Con+,0141,57,"MADRN McConnellsburg Fulton County"
Con+,119,1,"FleetTalk Catonsville Baltimore County"
Con+,119,2,"FleetTalk Silver Spring Montgomery County"
Con+,119,3,"FleetTalk Upper Marlboro Prince George's County"
Con+,119,4,"FleetTalk Falls Church Fairfax County"
Con+,119,5,"FleetTalk Baltimore Site Baltimore County"
Con+,119,6,"FleetTalk Frederick Site Frederick County"
Con+,119,7,"FleetTalk Charlotte Hall St. Mary's County"
Con+,119,8,"FleetTalk Independent Hill Prince William County"
P25, BEE00.170, 1.7, "WVIRP Berkeley County"
P25, BEE00.170, 1.23, "WVIRP Jefferson County"
P25, BEE00.170, 1.26, "WVIRP Romney Hampshire County"
P25, BEE00.170, 1.27, "WVIRP Ridge Hampshire County"
P25, BEE00.170, 1.47, "WVIRP Berkeley Springs Morgan County"
P25, BEE00.170, 1.48, "WVIRP Wardensville Hardy County"
P25, BEE00.170, 1.49, "WVIRP Mount Weather Site Bluemont VA"
P25, BEE00.170, 1.50, "WVIRP Paw Paw Morgan County
P25, BEE00.170, 1.52, "WVIRP Fort Ashby Mineral County"
P25, BEE00.277, 1.1, "Washington County MD Simulcast"
P25, BEE00.394, 1.1, "Franklin County PA System Simulcast"
P25, BEE00.394, 1.2, "Franklin County PA System Mount Quirauk"
bobruzzo
W1AV
WOW thats a lot of stuff! I am having trouble with all the numbers.........I dont know how to add an NXDN trunking system. It is a small local one. I am too confused with the format of what you have to type in the "sitelist" file....I cant find certain things in the RR database. Here are some screenshots of the system I want to hear but I dont have a clue how to assemble it. I read in another post how the freqs have to be entered a certain way and I cant find a "Network ID" in there. And where do I put the frequencies???
cg
Connecticut
At the beginning of each of the files, Network, Sites, Frequencies, there is a line or two explaining how to format the entries. Pretty easy, follow that format.
chris
bobruzzo
W1AV
chris
I dont see anything about "network ID" in the screen shots I posted.....I can see everything but Network ID. The instruction in the "Trunking.txt" file TELLS you WHAT to do but not HOW to do it! If there is no "Network ID" to be found what do I do?
air-scan
It would be good to edit DSDPlus. Frequencies before anything else.
A local suburb of my city is Midwest City which has NXDN 4800
First line is just a commented label for organizing. Commented out by a ; Standard procedure.
First you will need to tune to the Control Channel in in FMP24 (just enter with your keyboard then press enter) then DSD+FL will populate what it sees in the bottom of the DSD+FL window.
You want that RAN number it gives you.
;Midwest City NEXEDGE48
MODE|RAN|Site|LCN|Frequency
NEXEDGE48, 410, 1, 1, 853.1375,0.0,0
NEXEDGE48, 410, 1, 2, 852.7250,0.0,0
NEXEDGE48, 410, 1, 3, 851.1375,0.0,0
Get us the info DSD+FL says right there on the very utmost bottom of the DSD+FL Event window
u2brent
OAMPT
KRWDPAXKRS1
Code:
; DSD+ networks file
; you can edit this file while DSD+ is running
; line format: protocol, networkID, "network name"[, TIIIareaLength]
DMR, 0, "HAM DMR"
NEXEDGE48, 51, "Radio-Phone Communications RI"
Code:
;  DSD+ sites file
; line format: protocol, networkID, siteNumber, "site name"
;  for TIII, siteNumber format = area.site
NEXEDGE48, 51, 1, "Cranston/Providence RI"
NEXEDGE48, 51, 2, "West Warwick/Kent RI"
NEXEDGE48, 51, 3, "Exeter/Kent RI"
bobruzzo
W1AV
OK this is what I have in the first picture below.....I tried a hack 'n yack quick attempt at entering the data in the 3 files in DSD plus folder. So then I started up the program and the output is what you see in first picture. The second picture shows all this streaming data going by.....I DID hear a brief voice transmission. Not sure I set this all up correctly.
air-scan
Okay easy enough here you go:
;Radio-Phone Communications Rhode Island
NXDN48, 51, 1, 1, 451.9625, 0.0, 0
NXDN48, 51, 1, 2, 451.9875, 0.0, 0
NXDN48, 51, 1, 3, 472.1125, 0.0, 0
NXDN48, 51, 1, 4, 472.4375, 0.0, 0
NXDN48, 51, 1, 5, 472.6375, 0.0, 0
Copy those lines over to your DSD.Frequncies file. Append it don't overwrite anything else. save then DSD+FL will use it.
RAN 51 Site 1 remember that
u2brent
OAMPT
KRWDPAXKRS1
Code:
; DSD+ frequency file
; line format:
;  protocol, networkID, siteNumber, OTAchannelNumber, TXfrequency, RXfrequency, sortOrder
;   use site number = 0 for network-wide definition
;   use 0.0 for unknown frequencies
;   use sort order = 0 to sort by OTA channel number
; protocols:
;  D-Star
;  IDAS
;  NEXEDGE48
;  NEXEDGE96
;  dPMR
;  DMR
;  Cap+
;  Con+
;  TIII
;  P25
;  ProVoice
NEXEDGE48, 51, 1,    158, 451.96250, 0.0, 0
NEXEDGE48, 51, 1,    160, 451.98750, 0.0, 0
NEXEDGE48, 51, 1,    890, 472.11250, 0.0, 0
NEXEDGE48, 51, 1,    916, 472.43750, 0.0, 0
NEXEDGE48, 51, 1,    932, 472.63750, 0.0, 0
air-scan
We're here to help! I was in your shoes before. I didn't understand nothing about setting up trunked systems in DSD+FL. If it wasn't for RR I would be in the corner twiddling thumbs lol!
bobruzzo
W1AV
I don't do well with some of the instructions in those files in DSD folder. They are too vague and I tend to overthink it. I would rather have clear, to the point step by step instructions that I can easily follow. So apparently you can only monitor ONE system at a time with this set up?
air-scan
If you have more dongles you can also run 1RA.bat for another system.
I think @blantonl said in a thread some time ago he is working on a system that is compatible to DSD+FL which is a work in progress. Not all systems have those files for yet. I don't know how that is coming along.
u2brent
OAMPT
KRWDPAXKRS1
Code:
; DSD+ system/site loader file
; line format:
;   trunked network entries:
;     protocol, networkID, 0, "network name"
;   trunked site entries:
;     protocol, networkID, siteNumber, "site name"
;   conventional channel entries:
;     Conventional, pseudoNID, pseudoSiteNumber, "frequencyInMHZ protocol channelName"
;       note: "Conventional" can be shortened to "Conv"
;       recognized conventional channel protocol names:
;         Analog  (NFM analog)
;         FM      (NFM analog)
;         AM      (AM analog - must be supported by FMPx)
;         D-Star
;         Fusion
;         NXDN48
;         NXDN96
;         DMR
;         DCDM
;         dPMR
;         ProVoice
; trunked site entries can be copied directly from your DSDPlus.sites file
; frequency data for P25 trunked sites has to be present in the DSDPlus.P25data file;
;  manually tune to P25 control channels to auto-build the DSDPlus.P25data file
; frequency data for non-P25 trunked sites has to be present in the DSDPlus.frequencies file;
;  this data has to be manually added to the DSDPlus.frequencies file by you
; frequency data for conventional channels must be present
;  in every conventional channel entry in this file.
;  Conventional channel data does not have to be added to any other DSD+ data file
; data for any site or channel can be present more than once,
;  i.e. favorite / frequently monitored channels/sites could be duplicated at the top of this file
; examples:
DMR, 0, 0, "HAM"
NEXEDGE48, 51, 0, "Radio-Phone Communications RI"
Conv, 1, 14, "162.550        WX1"
Conv, 1, 15, "162.400        WX2"
Conv, 1, 16, "162.475        WX3"
Conv, 1, 17, "162.425        WX4"
Conv, 1, 18, "162.450        WX5"
Conv, 1, 19, "162.500        WX6"
Conv, 1, 20, "162.525        WX7"
Conv, 1, 21, "161.650        WX8"
Conv, 1, 22, "161.775 Analog WX9"
Conv, 1, 23, "163.275 FM     WX10"
bobruzzo
W1AV
Hahahaha I think I gotta get used to dealing with ONE dongle for now! I might have room for a second one in future, but USB ports limited on this computer. Well I got it all copied/pasted all the data in all the right places. Now I can see the way it is done. I left out the last site, the "Exeter" one cause it is outta range from here. Thats way out in the country. Maybe now I can start to play with DMR.......no clue how it works. I might be back in here at some point. However there isn't much DMR going on around here.
air-scan
DMR is funner. :cry:
Enjoy scanning!
