A Report On Pa Starnet
talviar
Uniontown, PA
Bob,
This isn't a report on PA Starnet solely. . . This is a report on the Interop needs of individual counties and areas as an outlined requirement for the DHS Interop Funding that was started last fall.
Looking thru the report I see many sperate interop initiatives existing or wanting to be developed outside of "PA Starnet" and see it as a good sign that all info asked of the respective counties got included in the report "unedited"
I can personally vouch for that as Fayette's info is in as we entered it into the questionaire last fall.
Tony Alviar
Fayette County EMA/911
