Abbeville SC Question
#1
Was hoping to solve my problem reading all the good information that is on this site, however I need some help.
I am using a RTL-SDR RTL 2832U with Unitrunker Ver. 1.0.33.4, DSD Plus 1.101PT.
Also using Visual Audio Cable to pipe the digital through.
I am trying to scan Abbeville County South Carolina using the control frequency of 855.5125.
I have the receiver set to chase, rather than discover.
I am receiving SCHP and EMS from Greenwood County, most everything but Abbeville County. I did think I heard Abbeville dispatch once. The receive strength is very good and the audio quality is
good also. DSD plus is creating a wave file.
Not sure if Abbeville has gone to P25 Phase II, if so that would explain why I cannot hear them. Based on RR Database it does not appear they have switched to Phase II.
Thanks for any help. Marshall
HummerMike
Abbeville, S.C.
#2
Hello Marshall .......... small world. I live in Abbeville also. Your control channel is correct. Abbeville 800 is digital, but not phase II. I can pick them up fine on a Whistler ws1065, and a Uniden 996p2 that I have in my car. The WS1065 will do PI but not PII.
Mike
#3
Hey Mike,
Good to hear from you. Hope all is going well since you moved to the area. Thanks for the confirmation on Abbevile county being Phase I. I am about 99% to getting this device working like I want it.
Thanks for the input.
Marshall
#4
Think my problem is solved. Downloaded the RR database to Unitrunker and am now scanning all the frequencies for the site or control channel.
Marshall
