About Programer!
rbo
Quebec city
Hi Everybody!
This is my first post on the forum and I have a problem with programer.Everything was working just fine till I got a message telling me that something occured and that it might not work properly.
Now, when I'm trying to communicate with the 700p I get this message;"serial port in use by another application or not supported in hardware"
I find the connection named "TTL 232 R" and it tells me that the pilots are not instaled.I run the cd to reinstall programmer but it won't fix the problem.I use the usb cable from Price Industries.
I hope this make sense to somebody,any help would be greately apreciated.
Thank you!
Bert.
rbo
Quebec city
Can't beleive I fixed this all by myself.I don't understand what caused this problem but I got it fixed by restoring my computer to a earlier date.
Thank you anyways!
Texas
While Programmer is talking to the radio, it takes control of the serial port - so any time the little pop-up boxes are open in either programmer, maintainance or RPM, the port is controlled. When the pop-up goes away, the port is free again. If you hang it up while there's a box up then you've locked the port.
Did you try rebooting the PC - I'd be surprised if that didn't fix it.....
rbo
Quebec city
Thank you for your answer!
It's working now.I did reboot the computer after restoring it the way it was a week earlier when I knew it was possible to communicate with the radio.I'll be aware of the popups you mentionned.
Thanks again!
Bert.
