Was curious if anyone with a 325 provides a live scanner feed with tags, and if so how do you do it.
The scanner sends/receives data and is powered by the same USB port, so unless it is currently powered by batteries, it won't work. It seems like USB ports just ain't powerful enough to turn the scanner on.
What im really asking is, is there a way to use the port on the scanner for both data and power (without batteries) at the same time.
