So I got my first CB radio to install in my suburban! ^_^ But I seem to be having some issues...
I currently have a Firestik antenna installed to a Diamond K9000 motorized mount. I opted to ground the antenna to the roof of the suburban and hooked it all up to my Cobra 29 LX.
When I hooked the antenna up to the radio I get a warning from the radio regarding the antenna when I attempt to calibrate it (I was just following the instructions from the radio for calibration...). I popped out my multimeter and measured the resistance between the outer shield and inner wire and found a resistance of 600k ohms. It's my understanding that is supposed to be an open circuit. But being a noob here I'm not exactly sure how "open" the open circuit needs to be. IE; should the multimeter simply read no connection ("0 ohms")? Or is 600k ohms open enough??
