Acronyms Aboard Navy Ships
n4jri
Richmond, VA
Been going through the Wiki and the Internet, but not finding a very comprehensive list of acronyms that would be heard in shipboard comms. Stuff like CIC, XO, CDO seem easier to flesh out, but there are a number of others. (am particularly curious about one that I think may be ATWO) Can anybody point me toward a good list of acronyms/jargon that would serve our particular needs well?
Another, related question: Would some of the jargon being used in the movie Captain Phillips or the TV show The Last Ship be accurate enough to give me some education?
73/Allen (N4JRI)
krokus
Southeastern Michigan
Nothing jumps out, about either of those, ad being egregiously bad. (Standard Hollywood embellishments type of stuff.)
Crimson Tide was about as accurate as Super Troopers, maybe less so.
ecps92
Taxachusetts
As said some are easy to find and determine, such as
CIC = Combat Information Center
XO = Executive Officer
CDO = Command Duty Officer
Others, well, all depends on the accent used and if you are used to that accent
New England, NY/NJ, Southern drawl etc
ATWO was likely ASWO
try here as one resourse
73/Allen (N4JRI)
n4jri
Richmond, VA
Context of ATWO probably not right for anti-sub. At first, I thought it might be the name 'Atwell' but unlikely on more than one ship in the same context. Visited the sites mentioned, but not much luck on several fronts. Was hoping to find a list of people who would ID by acronym on radio--particularly if that acronym might be unique to certain types of vessels.
73/Allen (N4JRI)
n4jri
Richmond, VA
Likely it is ASWO.
  • ASWO – Anti-Submarine Warfare Officer
Heard it again on the TV show 'The Last Ship', and closed captioning gave it an extra T, for ATTWO. Internet says it's 'Antiterrorism Tactical Watch Officer', and the context in the show was correct. The show also had a helicopter depicted searching 'zones' numbered up to 8, which also appears to match real life activity I've heard. Zones appeared to be numbered up to 8, and I assume that they would be slices of the area around the ship (45 degrees wide if all are equal?) possibly defined by the ship's bearing. Not sure how helos would determine what zone they're in if the ship isn't squawking AIS--would a destroyer have TACAN going if it had aircraft in the air?
73/Allen (N4JRI)
mass-man
trying to retire...
Parker Co., TX
Allen...please don’t try to correlate anything from a TV show to even a small slice of reality! While these shows may have a former USN member as a technical advisor, the producers and writers always win. Especially when it comes to the script...
Spoken as a 50+ year TV production technician..
ecps92
Taxachusetts
Like using a Scanner as a Cellphone or twoway radio :)
n4jri
Richmond, VA
Well, the TV show knew ATTWO and used it in the same context that I observed when hearing it myself. Nobody here even recognized it.
As for the helos using the 'zones', that may or may not be realistic. That sort of operation would not likely take place where I could hear it.
73/Allen
