Ada County -hmmmmm
Athol, Idaho
#2
Great Article. We all know that with anything new there is bound to be some glitches. But to use the system before it is safe is a real factor. Digital is good, but it should be proven before being used in the field. Just MHO.
#3
To be fair though that article was about an incident from 2008 and from my understanding the new IMBE in the APX is *much* improved.
There's a good video on YouTube showing an agency that did tests with all major radio makers with full gear on, sirens, etc.
The newer vocoders do a much better job than the first generation digital radios.
