Ada on State Trunked System
fast2okc
Oklahoma City, OK
The Ada and Tishomingo sites are now on line and the Pontotoc County Sheriff is now on the state system. Dispatch is TG 17200 and it is non-encrypted digital.
--fast2okc
n5bew1
norman, ok
Well what site can they use? Lexington or has something new popped up down in Troop F land.
n5bew1
norman, ok
I understood what you wrote the second time I read it. That is interesting sneaking new sites on the air a little bit at a time I guess. I may have to put that other 800 Mhz 10 element beam up I have and point it towards Ada.
mikebennett
Sherman, TX
The Tishomingo site has good range. I'm picking them up mobile at work in McKinney, TX. The only TGRP I've heard so far is Pontotoc SO on analog.
Mike
n5bew1
norman, ok
The FCC database lists the tower structure as being right at 415 ft tall. The antenna is listed as about 407
feet up the tower side mounted.
highrider8433
I've been hearing Ponotoch County on site40 for almost two weeks. I'm also hearing a tribal pd as well.
n5bew1
norman, ok
Digital 17200 that is all that brrrraappping I was hearing before I locked it out.Hee Hee
