Ada PD now Mototrbo
ecollins11
Ada, Oklahoma
Ada PD shut down their analog repeater on 158.775 yesterday and they have their Mototrbo Repeater on 158.775 up and running . They are now Mototrbo (They should have went with 800 P25) ...
ecollins11
Ada, Oklahoma
The Analog Repeater will be used as a backup if the Mototrbo Repeater is down
plaws
O-o-o-o-o-o-o-klahoma
Hurray! Now none of their neighboring jurisdictions will be able to hear them or talk to them. Bravo!
ecollins11
Ada, Oklahoma
The only way to decode MotoTrbo is spend big bucks for a Motorola MotoTrbo Hand held or a Mobile, I heard that there is program out that will decode it, the program is DSD I have not tried it yet...
ecollins11
Ada, Oklahoma
(UPDATE) Ada PD is now on 911 Channel
Due to problems with their MotoTrbo Repeater they are on their 911 Analog Channel 151.730 with a 151.4 ctcss tone untill futher notice...
savatage65
ada,ok
info
i was told by a guy from radio shack last week that they had 2 scanners that will pick up ada pd,pro 106&pro 197,he said price on the handheld and base model is 299.00
ecollins11
Ada, Oklahoma
NO !!! the only way you can listen to Ada PD is buy a Motorola MotoTrbo radio from Motorola, The 106 and 197 is P25 digital and MotoTrbo is not P25.
Freqed
Broken Arrow
I don't blame the guy @ RS since Ada just switched to Mototrbo. He's just not up to date....
