Adams County - p25 Radio System
LowImpedance
I am in Hanover, PA and I recently activated a PRO 668 I purchased two years ago. Using the included Radio Shack CDAT software, I successfully updated its firmware and library and I installed several trunked systems for York County, Adams County, etc. I am receiving York County but nothing from Adams. I have made sure the Adams talk groups are in an active playlist and experimented with FM vs NFM, locking out either the east or west system, and varying the data decode thresholds with the same results. Any suggestions?
W3DMV
Gettysburg, Pa
Several things to try
1. Make sure "auto fill" is checked for each site
2. Hanover is troubled by multi path. Site in the Pigeon Hills, and
McSherrystown. Try it with the antenna removed. If that fails,
try a paper clip in the BNC antenna connector.
Those are the only things that come to mind.
I have a PSR800 which works fine.
The info in the data base is correct.
Good luck
