Adapt Kraco mic to Cobra
RRLOGIN
I'm trying to install a mic on the cheap for a Cobra 21 LTD WX. I do have the wiring plug however and it's of the standard 4 pin square design. I have a donor mic from a Kraco KCB-4007, but it's a 5 pin variety in the shape of a half circle instead of the pentagon style. Is there an adapter made for this kind of job? Would I be better off trying to find an unwired mic for sale, or cutting the connector off the Kraco?
hhrj
SC Low Country
Open up the mic and see what the wire colors are and the the connections. You didn't specify that you have the Cobra mic but open it too and take a look. Can you take the Cobra mic plug apart? I doubt that you willl find any kind of adaptor.
Most of these mics are similar in wiring and operation but use different plugs and pin assignments. It's quite possible that the Kraco mic is only using 4 pins.
When I drove trucks I've had to buy a new mic at a truck stop and would change the plug to match my radio. I used one of those 12v soldering irons that takes forever to heat enough to melt the solder, what an frustrating POS that was.
Use an ohm meter to verify the pins and match the new mic to the old one.
Also search for wiring diagrams for the two radios an compare the mic wiring.
Good Luck
Ron
