Added dual-band magnet mount for GMRS to my car. Will it affect my CB antenna?
FPR1981
I added a Tram dual band magnet mount antenna for my GMRS rig to my car. I have a Tram 3500 (Wilson 1000 clone) on the trunk lid. I moved the Tram CB antenna to the passenger side of the trunk lid and the dual band (much smaller) to the other side of it. Will adding the dual band antenna cause me any issues with my CB antenna?
I am kicking around ditching the 3500 and going back to the Tram 300, and putting the 300 on the roof (the 3500 is a hair too tall and looks like hell on the roof) and then putting the dual band on the trunk lid.
Thoughts?
nhfdcadet
GCT-1
New Hartford, Ct
I don't think it would cause any problem with it, GMRS is pretty far away from CB as far as frequency goes, worst case it may just cancel an incoming transmission if you key it at the same time that the CB is receiving.
The only issue is you've created lopsided ground planes for each antenna, which will likely make them slightly directional.
Usually putting UHF antennas on the trunk results in some shadowing towards the front of the car. If you can get it on the roof, it will have a better ground plane and no shadowing. Put the CB antenna back on the center of the trunk.
DaveJacobsen
Moving...
As mckenna said --moving the antenna will cause more of an issue than the other antenna will....just be sure to retune the antenna if you're going to leave it there...
I would keep everything centerline - gmrs antenna on roof & cb on trunk ...
