Adding TG using Win 500 program.
gman51
I am pretty familiar with using the Win 96 program. Just wondering if this is the correct procedure to add a trunk group to an existing list using the win 500 program. Go to tsys tab, highlight list you want to add tg to, highlight tgrp, and then go to edit menu and insert item, and finally add the tg. Sorry if this sound confusing.
Gary
DonS
Franktown, CO
That's one way. There are several possible "paths". Here's how I do it:
1. select TSYS tab
2. click on TSYS to which I want to add a TGRP
3. click in the TGRP list somewhere
4. press CTRL+SHIFT+N (adds a new item at the end of the list of TGRPs, scrolls to that new item)
bneilson
South Jordan, Utah
1. select TSYS tab
This is what I do as well, but then I also go one step further and redefine the Object ID. This way I can control the order of the TGs in the scanner.
