thebaldgeek
thebaldgeek
We have increased the ground stations to 60.
Is there somewhere we can look up their codes to find their locations?
Added the filter for 12404A. We will see about tweaking the code so you can put any ground station in and it will filter for that one.
It might be Mexico. Here is a heat map of 15 hours of VDL location reports;
You can run this any time you like via the multi-fuction map and check the layers you want.
PHX generated this yesterday and is actively looking to bump up his coverage after he saw it. <grin>
I will leave the CPDLC filter as it is then. It's an easy string to search for and trap. AT1 can get lost pretty easily....
HFDL... yeah. Nice catch... I am a little embarrassed about that one... We have a huge noise floor. I think it's all the computer gear we are running. (I have 89 devices on my home network).
Bottom line, I know it needs improving and its pretty high on the todo list. I am running a north-south end fed long wire. We are in a HOA so have to be a little careful how much wire we put in the air, it's also a pretty small block of land, so again, the end feed is way easier than a dipole. Its an Alinco RX.
Also on my todo list to update the station list on that setup.
We have added the CPDLC filter/section to the HF filters.
