Advanced Receiver Research P30-1000 Preamp
radiowaves
Hey Group.
Been trying several different preamps on my RS Discone @ 35' to help bring in some distance aviation traffic, not really finding anything that works good. I was thinking about adding this one at the antenna: ARR P30-1000/11VD
http://www.advancedreceiver.com/page47.html
Has anyone tried this?
Also thinking about a yagi instead of a Discone.
Ideas?
Thanks,
Chad
N0Yk
prcguy
If you live in an RF rich environment it will produce all kinds of extra signals to clog your receiver, unless you put a band pass filter in front of it. If all you want is VHF air band you can do a lot better on noise figure, a preamp for that specific band should be well under 1dB. If you get one of these filters:
http://www.scannermaster.com/BPF_AIR_Air_Band_Band_Pass_Filter_p/24-531022.htm
you can shop for preamps with a better noise figure and you could probably get by with a lower 1dB compression point. Stick everything in a box at the base of the antenna and it should work well.
prcguy
