Advice for a newbie using a PRO 94?
Ladysmith
So I have recently acquired a PRO94, it is my first trunking scanner. I am slowly learning about it and how to program. I live in Spotsylvania County,VA and the primary system is EDACS. My main concerns being this...
What should I expect to hear on this scanner? I understand the whole rebanding thing but not enough to know if I will be able to hear anything on an EDACS system. I see that there are system freq's as well as system talkgroups, what is the correlation? Any info is greatly appreciated, like I said I'm new to the hobby and would really like to understand how trunking works.
Thanks all
jamesa53
IN
When rebanding occurs, just program in the new CC (control channel) freqs in LCN order, and start with Channel 1 not 0. Thats all you need to do.
The EDACS system you are trying to monitor is almost all analog, so you should be able to hear almost all of it. You can either run the scanner with open bank mode which will pick up any talkgroup or enter in the talkgroups you are interested in and run the scanner with closed bank mode.
Heres the link to the system I think you are trying to monitor:
http://www.radioreference.com/apps/db/?sid=513.
aharry
Lakeland, Florida
Pro-94
The PRO-94 was my first trunking scanner and I have to be honest, I hated that thing! I never felt like I understood a thing about it. I think it was at least 10 years ago that I bought it, the book was horrible and there weren’t so many web resources to get help as there are now. It sat in a drawer for probably the last 7 years. Every now and then I would pull it out, twiddle with it a while, and shove it back in the drawer. It wasn’t until about 2 months ago that I decided I should get a new scanner, so I picked up a BR330T. I’ll tell you with the dynamic memory, alpha tags, pc programming, and radio reference, I was up and running in no time and actually had a much better understanding of what was going on.
Anyway, my new found understanding of how the systems actually worked allowed me to dust off the old PRO-94 and put it to work again. As a matter of fact it is feeding a live feed here now. In early scanners frequencies were thought of as the channels, a police department might use one frequency as channel A and a second frequency as channel B. With trunking the frequencies are not really the channels, a conversation on a particular channel could be on any of the frequencies of the system. The talkgroups are the real channels.
So what you want to do is decided what channels (talkgroups) you want to monitor and program them into group lists. As another poster mentioned you can also “search” talkgroups of a system which means the radio will stop and monitor any talkgroup it comes across. This is a great way to find new groups, but is not ideal for monitoring because you don’t want the radio stopping on the sanitation department talking about the next dumpster they need to get during a high speed police pursuit! This is where I went wrong with my PRO-94. I didn’t really understand the talkgroup lists which are “scanned” versus “searching” for talkgroups across the system. So I would have the scanner in “search” mode and just lockout the talkgroups that I didn’t want to hear. Over time it was hard to know exactly what was on/off, etc.
When programming an EDACS System you Heve to program ALL frequencies. & with re banding the lcns will change & all freqs above 866mhz ( i think that;s the range will drop by 15Mhz ex: 866.2375 will be 851.2375 etc. if frequency ends in Zero( 4th digit), YOU will be outta luck & need to upgrade scanners. This is all from memory so someone will correct me If I am wrong
Ladysmith
Thank you guys for all the info. aharry, I am understanding more from reading your post, thanks for putting things in more 'understandable' terms. I'll have to lurk around the web for a bit tonight and figure out exactly (as in step by step) how to program this. :p
Ladysmith
Ok so here are the freq's that I am programming in
01 856.48750c
02 857.48750c
03 858.48750c
04 859.48750c
05 860.48750
06 866.61250
07 867.40000
08 867.67500
09 867.17500
10 867.62500
11 868.10000
Site 2 (I have no idea what this means)
00 859.23750c
00 858.23750c
Now here is where I am snagged. Do I program these freq's into CHANNELS or into BANKS? The way the manual is describing it seems like banks but I'm thinking I am mistaken.
Now the 'Site 2' deal, am I programming these in LCN as well or are they something different all together?
N8IAA
Fortunately, GA
01 856.48750c
02 857.48750c
03 858.48750c
04 859.48750c
05 860.48750
06 866.61250
07 867.40000
08 867.67500
09 867.17500
10 867.62500
11 868.10000
00 859.23750c
00 858.23750c
Definitely the CHANNELS:) Skip Channel 0. Start programming in 01, 02, etc.until all 11 frequencies are programmed. Make sure that they are programmed ED. Then just scan. When it stops on a TG, do what the manual says to save it to a Scan List. Site 2 would have to be programmed into a separate bank. But, they are Control Channels only, which don't work in the 94.
HTH,
Larry
