Advice For Programming VX-2200
ccravens
Portageville, MO
I am planning on purchasing a new radio in the next few months and have decided that the VX-2200 seems to be the best option for me. The main thing I am looking for is more or less your opinions on how difficult it is to program. I have programmed countless scanners for other people but they way I understand it radios are much more complicated. It would be a lot cheaper for me to program the radio myself rather than have the local shop to do it, since they charge $1 per channel and I will probably have to reprogram it from time to time. Any good advice will help me make my decision. Thanks.
stevelton
I am an Icom dealer, so I am really used to programming Icom radios. I was asked to get the programming cables and software for a few vertex radios for Our local EMA. I took me a few times of reading the help menu, but after about 3 hours, I had figured most of the options out. I programmed these with windows XP and a real vertex cable, not a clone.
They are nice radios. One of the things I really like about the vx2200. You can program the buttons for many different things, for a long hold down, or a momentary press. But the one thing it lacks, there is no way to re-write the priority channel. This is useful if certain days you are on call for fire, and then other times on call for EMT.
Steven
auxscan
Brooklyn, NY
better than brooklyn
you got it good, my local dealer charges $40 a zone, so 16 channels for $40 BUCKS. So two $2.50 for each channel.
However the department dealer charges $40 per a radio. So if you have a 200 ch radio or 512 ch radio programming all the frequencies would be $40. So two cents per a channel lol.
Maverick22
Steven, I have a vx2200 ltr model. There is an option to assign a button as the home channel set. The way i understand it, the home channel is the priority channel. I dont have a conventional model and it may (and probably is since i havent seen one) be different.
Maverick22
You will also have to enable home channel scan. If you cant find it, let me know and i'll look it up.
ColonelMike
Shepherdsville, KY
When programming a narrowband channel in, is it as easy as selecting narrow on the channel edit screen? I have done this but the voice is lower than other radio's when it is transmitting thru our narrowband channels on the repeater. Someone told me that I need to change something else to increase the loudness but I have no clue what they are talking about.
