kny2xb
1st: if this is in the wrong forum, I apologize.
I will be purchasing a mobile home/trailer towards the end of June.
Due to finances, I will be skipping cable TV and using my Zenith digital converters for over-the-air TV reception.
I'm planning to make a 48"- 50" height DIY coat hanger antenna to mount outside.
I have previously used a 20" height indoor version successfully, so that's why I'm going to go this route.
I also plan to make a quarter wave scanner antenna using wire and an SO-239 connector.
My questions are:
1] Should I use a metal mast, or PVC?
2] Can I use a long mast so that I can mount the scanner antenna above the TV antenna? Or should I make the antennas two separate installations/mounts?
3] I want to feed two tv's with the single TV antenna. Where would the best place to mount a two-output splitter?
Thank You in advance for your advice, help, suggestions, etc.
My questions are:
