Advice Needed For Pro96 Work
xusmarine1979
Louisville, Ohio
Hello all. I was wondering if there are any RS reps out there that can give me an idea how much a new body for my 96 would be, along with any "tweaks" they can do while they have it. I do have the upgrade for the DSP.
xusmarine1979
Louisville, Ohio
Not really sure. I read a post a while back and the gent. had some work done on his. If I recall he said they just made some tuning or something while they had it. I'm not even sure they charged him for it. I'm asking because my mom wants to send it in for me for my b-day, and wants me to give her some kind of an idea for the total cost. I'd guess no more than $100.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Someone recently ordered the rear casing with the rubber grips and stated the cost was about 18 bucks. A similar cost for the front would bring your total to about 86 dollars including the *tweaking*. You can call 800 the shac and get the parts cost.
xusmarine1979
Louisville, Ohio
I'll pretty much need the whole thing. Our 2yr old dropped it down the basement stairs a while back and ever since it seems to be falling apart. Still seems to work great though, but wasn't sure if something might have gotten knocked loose during the fall. Great, thanks for the quick response Sir.
John_M
Rochester, N.Y.
My rubber grips came off and I put them back on with superglue. They aren't coming off again. When I sent mine in for the CPU upgrade the work order said that the changed the cpu, tested all functions, and alligned circuits for maximum sensitivity.
KLH
Indiana
Here is the parts list for the PRO-96
Code:
RSU # Description Sug. Retail Availability Additional Description
11318532 DIODE 1N4002 RECT 600V.1A SI $.29 In Stock
10539476 ANTENNA,RUBBER 15.8CM $10.99 In Stock
12357570 CRYSTAL 20.945MHZ $8.13 In Stock
12357687 CRYSTAL 12.288MHZ $11.11 In Stock
12410833 COVER ASSY BATTERY $3.69 Not In Stock
12228805 HOLDER ASSY FOR RECHG. BTRY'S $5.99 In Stock
12228813 HOLDER ASSY BATTERY $5.99 In Stock
12410841 KEYTOP $13.89 In Stock
11274966 CLIP,BELT (FOR SCREWS 11717493 $2.79 In Stock
10720209 JACK,ANTENNA $8.29 In Stock
11840063 JACK,EARPHONE $2.87 Not In Stock
12228714 JACK POWER $2.49 Not In Stock
12193892 KNOB VOLUME/SQUELCH $2.49 Not In Stock
12357752 LCD $36.79 In Stock
12410783 LED FY1112H-1-TR $3.89 In Stock
12410858 MANUAL USERS 20-526 $4.99 In Stock
12411146 PRE LOADED PROGRAM GUIDE $2.49 In Stock
12357695 IC EEPROM HN58X24256FPI $17.99 In Stock
12410775 IC SMT TMP93PS44F $54.99 In Stock CPU 16-BIT MOS
12417416 SQUELCH ASSY $5.29 In Stock
10983344 POT ASSY,W/SWITCH VOLUME $8.75 In Stock
11717485 SPEAKER 8-OHM 500MW $11.89 In Stock
12410759 PCB ASSY LINEAR $139.99 Not In Stock
12410767 PCB ASSY LOGIC $249.99 In Stock
12410791 CASE ASSY FRONT $28.49 Not In Stock NON REPAIRABLE CONSISTS OF: CASE FRONT WINDOW LCD TAPE ADHESIVE HIMELON SPEAKER
12410809 CASE ASSY REAR $17.69 In Stock NON REPAIRABLE CONSISTS OF: CASE REAR GRIP (L)/(M)/(S) LABEL MODEL TAPE ADHESIVE FOR GRIP(L) TAPE ADHESIVE FOR GRIP(M) TAPE ADHESIVE FOR GRIP(S)
andy0018
Norfolk, VA
Pro-96 Refurb
Had my Pro-96 refurbed.. new case (front and back), speaker, keypad, knobs, clip, + general tune-up for $150ish including labor. You will wait awhile for parts though.
