Little bit of an update.
I met with my boss and the head electrician and biomed. I explained all the concerns you guys have mentioned.
Biomed is fine with the antennas as long as they are on the upper roof. I gave them all the information on frequencies, output, antenna type, etc.
The electrician accepted responsibility for dealing with the actual antenna mounting and lightning protection.
The electrician has a contractor they will get to do the cable pull.
Be careful with electricians. They can likely handle the antenna mounting and grounding. But pulling the cable is totally different than pulling electrical wire. Coax cannot be kinked. You may need to watch them pull the cable.
I've had electrical contractors install coax for me, but I supervise.
Installing coaxial connectors is well outside the experience level of your average electrician, especially the types of connectors you'll need on the size cable for that length of run. You can have them install the cable, but consider having a respected local radio shop come in and do the final connector install and testing (you really want the cable swept after termination). A good radio shop can do a lot for you.
I still can't figure out if the cable is riser rated. It doesn't say so on the label, so I'm assuming it's not. Boss agreed to buy the proper cable if necessary.
Unless you know for sure by running the manufactures part number, it isn't. RG-8 is no where near suitable for a run that long.
Boss vetoed the idea of putting the actual radios on the top floor.
That was to be expected. Finding an empty room in a hospital is nearly impossible. We've had to build out new telecom closets in medical facilities at work and it's always a huge challenge.
So, the cable and antenna are the responsibility of other people now.
My big problem now is that the cable run will actually be around 300 feet. That's a pretty big loss, especially for the UHF. Is there any type of signal booster we could install?
Yeah, that's going to be your big challenge.
300 feet of RG-8 is going to have 13dB of loss, which means your 50 watt UHF radio is going to result in about 2.3 watts actually making it to the antenna. That isn't going to work very well. Bigger issue will be that any received signal is going to be reduced by the same amount. That's going to result in a nearly deaf receiver. That makes is a pretty useless system.
7/8" Heliax is going to work much better. 2.4dB of loss, which is something you can actually work with. That means a 50 watt UHF radio is going to give you almost 29 watts out at the antenna end, and on the receive side that's a totally manageable amount of loss.
7/8" Heliax is going to need a 2" conduit.
Big issue is that 7/8" Heliax is going to be several dollars per foot. $5 buck a foot. So, you are looking at a few thousand dollars of cable, connectors and install labor.
The cable also needs to be grounded, so you'll need coax grounding kits, support kits for the vertical runs (to support the weight of the cable), coax connectors, sealing, etc.
On the VHF side, it's going to fare better.
For HF, you can do with lower grade cable. You could probably get by with the RG-8 if it was riser rated, but since it likely isn't you will need to use something else. Might as well get better cable. Most of the real costs is in the installation labor anyway.
For something like LMR-600-FR (riser rated) the loss is manageable, but you are still looking at several dollars per foot.
If it was me, I'd probably run 1/2" Heliax since the costs become similar and the performance is higher. Like I said, labor is the bigger cost.
You could do an amplifier/pre-amplifier set up, but then there's challenges with powering those, accessing them, locating them, etc. I could be made to work, but it's going to be a bigger challenge and not save any money at all. I use a tower top amplifier for one of my 800MHz systems, and it works, but we are looking at a narrow slice of spectrum and were still running large coaxial cable. It's not a good solution for your application.
And the radios and other stuff were provided by the state health department. All the surrounding hospitals have them too. But most of them are 2-3 floors.
There's an issue. Health Department specifying radio equipment in a boiler plate manner for all hospitals. While the core equipment might be fine, the coax and all the stuff they didn't include becomes a bigger issue.
