After shack remodel KE7KQB
ka1njl
Fairport, ,New York
Gorgeous!!
Your remodel is beautiful. I really like the built in cabinets and the custom look. I had a shack like that before my last move and I am slowly getting back to where I started. It makes such a difference when you have dedicated, purposefully designed space. Great job.
73
N8DRC
Grass Lake
Looks great nice shack you have there, what does the antenna farm look like?
jrule
Power
I think you are asking about the power supply and battery back-up.
I have a Astron RM-60 Power Supply running into a West Mountain Power Gate that charges my gel-cel battery and feeds power to the West Mountain 4012 Rig Runner with Anderson power poles. The PWRgate charges the battery with power from the power supply and automatically switches to battery back-up if the power goes out. Above that is a Andrews Ground bar for grounding the equipment. Also the blue box above the power supply is a solar panel charge controller . Still hooking up equipment and trying not to make a rats nest of all the wires that can be hard as we all now !! Hope that answers you ?'s 73'S
texasemt13
CenTex DBA
Hunter, TX
Your power supply setup is sweet. Nice that you can charge your battery while using a rig. Also sweet that it switches to batt back-up automatically.
Are you using a solar panel to charge the battery also?
jrule
Solar
No i have a solar panel but don't have it hooked up yet. Still looking for good place outside to mount them.
Would also like too have a large bank of batteries and some more panels . Maybe some day!! when i win the lottery .
