I've heard this is a Good antenna from Scanner Master
In my antenna farm, both of those are good general purpose airband improvements, but not great if your airband stations are just underneath the squelch level, or slightly above it but too noisy or unintelligible especially if they are below 128mhz.
Having an antenna actually resonant, or at least cut long enough abiding to the quarter-wave formula will reveal the difference under weak-signal conditions.
The W901 is only 8 inches long and is a small improvement over the oem scanner duck. It is also touted to be dual-band for UHF milair so that helps. Mine seemed happiest as a 2m amateur whip, but it may have been mislabeled.
The venerable RH77CA is only 15 inches long and is really a 2m/440 amateur dual bander. It is an even better improvement than the oem scanner duck on airband even if a little bit short. One reason for its popularity on vhf is that it seems that the 15 inch whip appears to be resonant high in the 2 meter band and is even happier at 150-155 mhz or so. Normally an amateur quarter wave whip is about 18 inches long, so maybe it being a slight bit shorter than usual helps it do dual-band duty for amateur uhf, and very good for vhf 146mhz + scanning. But for weak signal airband work - especially below 128 mhz, which is about 25 mhz or so below what the 77ca is designed for, can become noticeable.
Amazingly, the lash-up project where I put a 21 inch quarter wave wire against a radio shack oem duck works better than the rh77ca - but not by much - but the difference in weak signal strength compared to this IS noticeable. Anyone can make this simple test and is a great way to re-purpose that oem duck into something actually useful.
For those that need the convenience of a rubber-duck for airband, my suggestion is to use the Icom FA-B02AR which comes with their commercial airband transceivers. It can be had at most pilot shops. Performance is comparable to the much longer RH77CA which shows that resonance DOES make a difference. I suspect it has capacitive end-loading, but I'm not cutting mine open (yet).
