Aircraft newbie question...
Fortified Bunker
#1
I found a link on the FAA website where you can type in a tail number and it will whow you who owns that aircraft http://registry.faa.gov/aircraftinquiry/NNum_inquiry.asp I also found sites where you can track a specific flight by it's flight number such as flightaware.com, etc.
Is there any online database that tracks flights by their tail number? Since the flight number stays the same mostly between two airports but the actual aircraft may change, I'm interested in searching by tail number.
