Airplane freqs?
daneg
Lancaster County pa
I am kind of getting into picking up airplanes, like commercial jets and such. is this possible on a Pro 94? If so where can I find freqs for airlines that are in the air currently? I think I might be able to pick up ones that are flying over my area (lancaster pa area).
EvilSanta
For Lancaster Airport, KLNS
CTAF: 120.900
UNICOM: 122.950
ATIS: 125.675
LANCASTER GROUND: 121.800
LANCASTER TOWER: 120.900
HARRISBURG APPROACH: 126.450
HARRISBURG DEPARTURE: 126.450
EMERG: 121.500
Go here, and put in the airport you wish to tune into (it has to be local, non that are more than a state away.....)
http://www.airnav.com/airports/
trainman111
Richmond, VA
Try plugging in the approach/departure frequencies for Philadelphia Int'l, Dulles Int'l, Reagan Int'l, and Harrisburg, along with NY ARTCC, and ZDC ARTCC. With the right antenna, you should be able to hear any one of those. When I stayed in Gettysburg I as able to hear at least one frequencies from all of the above categories. The distance you can hear aircraft all depends on the aircraft altitude, antenna height and terrain. On good days I can hear aircraft transiting ZNY's KENNEDY sector. You should be able to pick up the ground side comms from a couple ZNY (NY ARTCC) frequencies also. You should have tons to listen to in Lancaster! Good luck!
