Airspy or SDRplay For FM Radio Monitoring?
AlfordSticks
Hello all. I want to listen to the FM broadcast band using SDR. I already have a generic SDR stick but would like to upgrade to an Airspy or SDRplay but which one is better for FM radio monitoring from 88 to 108 MHz? Thanks in advance.
iMONITOR
Silent Key
S.E. Michigan
Keep in mind this article is from 2016, I'm sure things have improved on both sides.
Airspy vs SDRPlay: Two New Comparison Videos
majoco
Stirrer
New Zealand
Why lock up a perfectly good scanner/receiver that's good for DC to daylight just for the FM BC band when there plenty of el cheapo receivers around for $5? Unless of course you want to go DX-ing when you should invest in a bigger antenna outside.
