Alberta NXDN
Jay911
Bragg Creek, Alberta
#1
Hi folks,
Like I did for DMR, I plan to make a spreadsheet of NXDN content as shown in the TAFL/Spectrum Management System. I'm just running behind the release of the firmware for those of you with Whistler radios. I hope to have something tonight or sometime tomorrow. In the meantime, you can probably fiddle with the ATCO Gas provincewide system, or Kearl, or Whyte, or one of several others in the database already.
Watch this space for more details soon...
Jay911
#2
Here we go...
This should be familiar to people who downloaded my DMR Excel file a while back.
I split off the ones which appear to be obviously "trunk" (type D, IIRC) into separate sheets.
Please let me know if you end up using the file...
Jay911
#3
Found an IDAS system... Prairie Mobile Communications has two freqs running on the CBC tower site at very close spacing: 143.110 is LCN 1 and 143.115 is LCN 2. Only user identified so far is Willco School Bus Lines.
In the 'patch
#4
That is tight spacing, but with good filtering, it is possible. I'm guessing there would be lots of combining losses on the transmit side, receive filtering would not be an issue though. Assuming a 148MHz or 149Mhz input, running one antenna would be really easy.
Sent from my iPad using Tapatalk
Vancouver BC
#5
As per IC form SRSP 500 spacing is 7.5 so 143.11 should be tuned to (C681-7.5Khz) 143.1075 mhz, however that is too close for a system , the license shows CFB481 143.115 & 143.64 8K10F1E-N (10K max) spacing so that is in line with 7.5 Khz spacing used in IDAS.
In my observations new licenses are not spaced so close together. I don't doubt your results but seems weird IC would put them side by side.
Jay911
#6
It was suggested in the Understanding IDAS Trunking thread that it might be 143.1125 and 143.1175. I'll entertain any ideas what the correct spacing is.
I did check the license - nothing on 143.64, nor on the freq that was listed on the license previously (143.925) in place of 143.64.
Makes me wonder, though, if I should look around between 143.635 and 143.65 for another "system".
Jay, if you have some questions about our IDAS system in Calgary, let me know.
Cam Milne
Technical Solutions Manager
