ALINCO DJ-MD5 programming question.
N4KVE
PALM BEACH, FLORIDA
I just picked up a used DJ-MD5. My friend has an Anytone 878. Can he program his code plug into my radio using Anytone CPS? From what I understand all the CCR’s use the same consulting company in China to write their CPS.
sallen07
Rochester, NY
I have a DJ-MD5 and an Anytone 578. Other that the font, the vendor-supplied CPS appear to be identical between the two.
But I do not believe you can do that since the CPS talks to the radio to make sure it is running a compatible firemware before it will upload the code plug. The two radios also will not have the same setup options.
What you *should* be able to do is export the code plug from the Anytone CPS and import it into the Alinco CPS.
