Alinco dx sr8 t mods
KD8DVR
Columbus, Ohio
#3
You can't. It's illegal.
AntiSquid Disclaimer: All posted content is personal opinion only and may not imply fact or accusation.
Mojave Ca
#7
Hello Space Man: Yes there are many Amateur Transceivers used for the CB Band. As a lot of amateurs slid down to use the CB and Free Bands.
I have said before that the inside word from Yaesu in the 1980's is that they believed approx. 30 percent of there HF Radios were sold for CB use. Most all of the Amateur HF Radios can easily be modified to cover the Mars Frequencies which also allows the CB Band to be used.
The Amateur HF radios are cleaner than a CB radio and a amp, I would think. Plus the receiver in the Amateur radios now have Digital Signal Processing (DSP) allowing receiver band width to be adjusted and reducing noise. A really significant plus for HF Communications.
I am sure the use of the Amateur Radios use on the CB Band has also induced many to get their Amateur License after tuning around listening to the Ham Bands. Way more than the unfriendly element of Amateurs reciting rules and running around in circles running new perspective hams off from the hobby.
Jay in the Great Mojave Desert
#8
Well said Jay
So Cali
#9
It is NOT illegal to make the mod.
Transmitting out of the ham band(s) would be a violation of the amateur rules.
Transmitting on CB with a non type accepted transmitter IS a violation.
This is covered in FCC Parts 97, 95 and other sections.
