All-in-One scanner
Spring, Texas
#1
I was wondering if anyone on this forum has created a All-in-One scanner using a Raspberry Pi and SDR dongle (R820T2).
I've been researching this solution and would like to share lessons learned.
Forts
Ontario, Canada
#2
It's been discussed, but I believe the limiting factor is the lack of horsepower from the Pi (especially if you want to run DSD/DSD+). There are many other boards out there that are much more robust (beagle boards etc) but of course code would have to be ported over, blah blah. It would be slick though, a unit like that with a small lcd display...
