Allied 2682 shortwave radio question
Shortwave2200
Tampa Florida
I just received my radio yesterday.
One question, when I change to AM BC band it comes in strong but then it fades out.
All of the other bands work great.
Any idea what it could be?
w2xq
Burlington County, NJ
Wirelessly posted (Moto Droid Bionic: Mozilla/5.0 (Linux; U; Android 4.1.2; en-us; DROID BIONIC Build/9.8.2O-72_VZW-22) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
Boy that radio brings back memories. I forgot I owned one back when. Looked it up on the net. Vintage late 1960's-1970's. I would suggest you try something simple first. Get a can of tuner cleaner and clean the bandswitch; don't over spray. Probably wouldn't hurt to spray the volume control and front panel controls. HTH.
w2xq
Deleted. Dunno why Wiforum s/w is so sensitive as to think the post key thinks it has been pressed twice.
w2xq
Deleted.
Shortwave2200
Tampa Florida
I used deoxit on all of the controls and the band selector.
What I found out is that it is a Ceramic Capacitor that has gone bad in the AM BC section but I cannot see the side where there is a number so I can buy a replacement.
Shortwave2200
Tampa Florida
Found problem
The capacitor that I thought was the problem was not.
There is one that is in front of the suspected one, in the cold the AM didn't work, brought it outside and the AM BC band would work, thermal...
So I took a chance and it now works.
That was the Allied Model, actually there are 2 Ceramic Capacitors 8pf and then on the opposit side of the board there is a 5pf, so I replaced the 8 and resoldered the 5pf back to where it was originally.
Then it got me thinking about the Aircastle, so for a preventive maint I replaced that one as well BUT it had a 15pf on it, I replaced it with a 8pf, it is alot more sensitive now, a hell of alot more.
Like I stated in a previous post, I do not like any of my shortwave radios past and present, to run on AC, so I desoldered the power supply from both units all the wires are desoldered from the mb and the power supply itself had 2 nuts holding it everything was removed batteries are more stable regulated 6V.
The batteries in these units seem like they are going to last a long time, i'd say over 100 hrs...
