- Joined
- Jan 20, 2012
- Messages
- 242
Trying to understand this issue that I'm having with an Alpha Delta DX-EE fan dipole.
SWR on 20, 15, and 10 meters are all acceptable, close to 2.0
SWR on 40 is 20.
The antenna is in my attic. There are no ducts in the area and no metal nearby.
Antenna height above ground is 10 feet to 18 feet due to the house being a split level with the front yard being higher than the back yard.
Two different, known good (using on other systems) feedlines tested with same result. One was a RG-6U and the other is a RG-213U.
Feedline run is under 30 feet.
I have confirmed the lugs (that connect the elements to the main housing) are tight.
20 meters works fine. I don't use 15 or 10 to have any practical experience with it.
40 meters would be great but with a SWR of 20, it's unusable.
Anyone have any ideas of what I could try?
Thank you and 73
Shortwaver
SWR on 40 is 20.
Thank you and 73
Shortwaver
