Alright...Whats DPL?
Medina OH
Sorry the title should say DPL!....Hey guys im trying to program my radio to 422.475......026 DPL and my radio specs say it can do DPL but in the programing software im not seeing it i have a thing call "DQT" Im guessing that means digital quit talk and the only opition i think i have is if i pull down that menu and set it to "D026N" I'm not sure if this will even work though! any ideas? is DQT the same as DPL? and is D026N the same as 026 DPL???? Thanks
kma371
Helps if you tell us which radio... :)
But it sounds like it's the same thing.
Sent from my iPhone 4 using Tapatalk
kayn1n32008
In the 'patch
Wirelessly posted (Mozilla/5.0 (BlackBerry; U; BlackBerry 9780; en-US) AppleWebKit/534.8+ (KHTML, like Gecko) Version/6.0.0.600 Mobile Safari/534.8+)
With DPL you have 'normal' and 'inverted' amplifiers that have a numer of amplifing stages that are odd will invert the DPL code, causing a reciever to see an invalid code
