I am having problems with alternator whine coming thru a 2096 I installed in my sisters' Subaru WRX. I fed it from the existing feed for the stock radio, and got the ground from an exposed metal framing member bolt behind the radio.
(The stock radio has no noise problems)
The noise is present even when the volume is all the way down, so I'm assuming it isn't radiated, but coming in on the power. Is it better to try to filter it at the alternator or the radio?
I have seen capacitors mounted right at the alternator, but also someone told me that sometimes a bad diode in the alternator can cause a whine.
Any advice?
Any advice?
