am i able to listen to ISS with a scanner?
mparker
Ohio
sorry for the newbie question, reading around on this section of the forum has peaked my interest...
am i able to just listen to ISS when it passes over my state with just a scanner? thanks guys...
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Yes you certainly can. An outdoor antenna will increase your chances considerably. Monitoring 145.8 will bring results when and if the amateur station is active. Keep in mind that the station is a secondary mission for the astronauts, and they will power it down when safety requires it (such as during spacewalks or cargo ship arrivals). The higher the pass, the greater the chance that you will hear it. There are many online tools to help you determine this. See our Satcom wiki for more information
73 Mike
mparker
Ohio
i cant figure out how to read the charts that show its path.... grrr
WouffHong
Jawjuh :)
ISS Listening...
Go to LIVE REAL TIME SATELLITE AND SPACE SHUTTLE TRACKING and it will show you where the ISS is right now.
Click on " 5 days prediction with graphics " and having read your IP address, it will show you a map of your location and a place where you can see the nearby passes (look at the elevation column) and with "draw" it will show you the "arc" of passes you select.
When the ISS is approaching you, go back to the original "main" page and click on both "Draw Lines" and "Show Footprint" for an excellent look at it's approach and if you are in the "footprint" of visibility and direction. :)
To hear Voice: 145.800
To hear Data (Ham Packet): 145.825
Frequency info is great at: ISS Frequencies | ISS Fan Club
Ham Calls heard via ISS can be seen at: Amateur Radio Stations heard via ISS
If you see "w4nov-2" - That's me. :)
:roll:
Yes - A Scanner will pick it up, but, as mentioned, an outside antenna would work best - I talk through ISS with a Comet GP3 dual-band Vertical with 20 watts and get almost as good results with a Diamond Discone at 30 feet. :)
Tom, W4NOV
mparker
Ohio
at the list i checked the box to show only visible passes.. but they seem so far away... there are others that pass directly over me...
whats the deal with that?
when is the best time for me to try to listen?
i am at
Latitude: 39.931735°
Longitude:-83.15938°
if anyone wants to see what i am seeing...
thanks guys...,
wx2watch
Merrimack River Valley, MA
re: ISS reception
Go to the following web site:
Heavens-Above Home Page
Select your geographic location on their home page and then go the page which is marked:
Radio Amateur Satellites
This will give you ALL passes of the ISS ( and other satellites) for your location.
Other "marked" pages will give you the visble satellites, planets, etc.
Regards,
John (Western NC - USA)
mparker
Ohio
here is what it tells me...
rdale
Lansing, MI
Don't search for visible, search for all.
mparker
Ohio
ok.. here is a little snippet.. the list was pretty long.. what does this all mean...
rdale
Lansing, MI
The "sightings" list is the same thing as visible. It means those are the passes you can see. You want all passes, which is your second img shot.
mparker
Ohio
so those start times i should tune in and see if i hear anything?
sounds to easy lol
mikelib
Barnegat, NJ 08005
A couple of days ago I was able to receive 9 seconds of packet data on 145.825. Using a BCD396T scanner hook up to a car CB antenna that is on the floor next to my couch. The scanner was hooked up to my computer sound card and I was running a AGW packet engine with a UI-viewer.
The ISS was right over my location and I received the following APRS Packets:
17:55:53R N8XYR>APRS,RS0ISS-3* Port=1 <UI Len=42>:
=4526.15N/08457.30W-Ken in en75mk {UISS52}
17:55:54R KC2PCR>APRS,RS0ISS-3* Port=1 <UI Len=34>:
:KI4TZ :Hi Joe -73 via ISS digi
17:55:54R RS0ISS-11>VA3NDO Port=1 <RR R F R1>
17:55:55R RS0ISS-11>VA3NDO Port=1 <I C P S3 R1 Len=22>:
CMD(F/K/M/R/W/B/H/?)>
17:56:08R KI4TZ>KC2PCR,RS0ISS-3* Port=1 <UI Len=18>:
packets seems slow
17:56:08R W4AEJ>APRS,RS0ISS-3* Port=1 <UI Len=29>:
=3031.90N/08626.91W- {UISS52}
17:56:09R VE9DKS>CQ,RS0ISS-3* Port=1 <UI R Len=20>:
VE9DKS Danny FN66FH
17:56:09R RS0ISS-11>VA3NDO Port=1 <RR R F R3>
17:56:09R RS0ISS-11>VA3NDO Port=1 <I C P S4 R3 Len=18>:
Subject:
Message:
Mike Lib
WA2ACV
rdale
Lansing, MI
Note they sleep from around 5pm to 3am EST, so don't try during those timeframes.
wx2watch
ISS and Heavens-above web page
For the Heavens-above web site, you need to choose:
Radio Amateur Satellites - 24 hour predictions (all passes)
That page will show MANY amateur satellites and their beacon frequencies.
(I can NOTguarantee the validity of any other than the 145.800 for ISS)
Look for an ISS prediction when the MAX ALTITUDE is greater than about 50 degrees for best results - then turn your scanner ON about a minute or two before max altitude happens for your location.
(It is also kind of neat to watch the ISS on those twilight passes when it is visible.)
Sometimes you will hear packets, sometimes voice from either the astronauts OR, when the cross-band repeater is on, you will hear other earth based hams. AND, sometimes you will hear SSTV (slow scan TV).
The last day or so, 145.800 has been silent in my location. Hard to say when the occupants of ISS have the time to monitor/respond. I got lucky the other day and heard someone repeat my call-sign, KG4LBJ, while trying the cross-band.
Uplink, IN THE US, talking to the ISS is 144.49
Uplink for cross-band is 237.800
Good luck (and keep listening)
John
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If memory serves the uplink when the x-band repeater is on is 437.8, not 237.8. Packet is on 145.825.
You would, of course, need to be fairly close to the sending station to have a chance at hearing the uplinks. Stick with 145.8. By the way, if the station is sending packet (that has been reported lately), there is software for decoding that, as well as software for SSTV, which they also have used in the past. Again, that's all documented on the wiki 73 Mike
wx2watch
ISS uplinks
OOPs, my mistake for quoting numbers in the middle of the night without double checking!! I should, indeed, have said 437.8 MHz for the uplink.
Thanks,
John
boyledad
Oklahoma
Even when there is no voice traffic on 145.80 the packet bursts on 145.825 will confirm that the pass schedules you are getting are correct. I heard three passes yesterday this way. The data bursts are a few seconds apart and if you are scanning both frequencies you should hear it. I can catch it with the mobile antenna on my truck all the way down to 8 degrees inclination.
