Perhaps the law should be written like how USPS writes its code for calculating limits to package size (length+girth), such that you could build tall and skinny or fat and wide, which would allow flexibility into how someone can design their antenna - a high monopole/dipole or a closer to ground beam antenna.
However the guy wires probably need to also be added into the calculation...
I'm suggesting that in order to override HOAs and local governments, it likely isn't going to have guy wires.
The point I was trying to make is that if we're already OK with allowing the federal government to override smaller forms of government, right down to the HOA, for TV antennas and DBS dishes, then let's allow any other use that fits within that same envelope.
My dimensions were too big, but basically take the largest TV antenna that may need to be used to pull in an acceptable signal, and allow people to put up any antenna that size or smaller for whatever purpose they want, including Internet, AM/FM broadcast radio, or amateur radio.
Once we get into guyed towers, we're likely over the level already allowed by OTARD.
