I'm in the Ameren area (south Jefferson Co MO), and have had one of the meters for about two years (got it when service was upgraded to 320A). We are rural, so I'm sure it helps them out on reading them.
The unit is a Landis+Gyr FOCUS with the Cellnet DSSS retrofit.
FCC ID: ROV-CLTR900M
The FCC's site has a LOT of good information that was submitted during the testing for compliance of the unit.
https://fjallfoss.fcc.gov/oetcf/eas...=N&application_id=477604&fcc_id='ROV-CLTR900M'
Landis+Gyr has the manual at
http://www.landisgyr.com/NA/Prod_PDFs/Focus Technical Manual Rev 2.5.pdf
The unit appears to transmit DSSS between 913.98 MHz and 917.58 MHz.
From what I understand, the units are designed to only send data every X seconds. It's actually pretty slick, the way they do it - they charge this cap on the transmitter board, and when its fully charged, it uses the cap's power to transmit the signal. They do this so that no one unit will chatter up the network, apparently, since no unit can continually transmit (since the transmitter has no power until the cap is charged).
There's a "currently transmitting" indicator on the unit, that will indicate when the unit is sending. Also, as mentioned previously, they do transmit 'dying gasps' to the network, and tamper alarms as well...
Reading up on this makes me want to know more, myself...
