American Electric Power (AEP) P25 WACN 92715
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
FYI folks. In the case of the Canton site, the new P25 site uses a completely different license with completely separate frequencies. However, all of the neighbors of Canton (which aren't online) use additional frequencies that were added to the existing licenses that serve the active EDACS sites.
The moral of the story is -- don't think that an EDACS site is simply going to magically switch to P25 one day. Instead, it appears they are building out the P25 sites alongside the EDACS and using a minimum of frequencies to accomplish that and test sites -- whilst leaving their EDACS counterparts fully entact during that period. And don't expect to see brand new licenses. Take a look at existing licenses for an EDACS site -- and likely one or more of those frequencies is not in use on the EDACS site and will be used instead to deploy the P25 site side by side.
So it's just best to scan 850-861 mhz occasionally, checking to see if you find a new P25 site with a WACN of 92715. The SysID will be different depending upon the territory you are in. I mean seriously, how long does it take to put a digital scanner into search mode and scan 850-861, stopping on any P25 site, checking its WACN and logging the details if ya find a new one? It takes me longer to use the can than it does to do the scan -- so take your scanner to the can with you :)
sopranosno1
Catching a possible control channel i think is coming from bellefontaine.855.3875 p25. site 002. N002. W: 92715. Sy 1f6. r002. S002
mtindor
OH/WV DB Admin
A current neighbor list from the Mt Sterling or suspected Bellefontaine site would be nice. I realize that if you caught that with your scanner, you may not have what is needed to find the site neighbor info. Hopefully somebody will attempt to though.
How far is Bellefontaine, Etna, Johnstown, Bloomfield and Cambridge from you? That looks like the only logical locations anywhere near central Ohio. You're probably right on Bellefontaine. Neighbor lists from Site 2 and Mt Sterling (neighbors and associated control channels) would certainly help though.
al_35
No edacs control channel is active, and all those other cities are far away from shelby county. So it has to be ''bellefontaine''.
mtindor
OH/WV DB Admin
I've added it, but it would really be nice if somebody within earshot of it would run a P25 trunking program on the CC and get all of the active frequencies / alternate CCs, site neighbors, and site neighbor frequencies.
It was never stated that it was monitored from within Shelby Co. That's useful information.
mtindor
OH/WV DB Admin
For those of you near Leonard OK, Mt Sterling OH or Bellefontaine OH who have the ability to run DSDPlus to monitor the site, please do so and report back all of the site neighbor information (neighbors, as well as the CC's listed for the neighboring sites).
AEP is making progress in Eastern Ohio. At this point there are [at least] four sites online in Eastern Ohio -- and only a short while ago there was only one online.
I have seen a ton of FCC updates this year for the AEP licenses in all of the states that they serve. I'd say there is a real good chance that other sites are online, and the best way to determine what else might be online is to check the neighbor list for any site currently known to be online.
Mike
mtindor
OH/WV DB Admin
Leonard has been displaying this the past month or so.
What frequency are you parked on when you monitor that? The DB says the Leonard site is 1F1-9.9. But what you are monitoring is 1F1-19.19.
For any site that you can pick up, can you post (a) active control channel, (b) any alternate control channels or frequencies seen in use on the same site, (c) and a list of all neighbors to the site (using N in DSDPlus to list the neighbors) ?
mike
wx5uif
Broken Arrow, OK
857.36250. It used to be site 9.9 and now has changed to 19.19. I'm not sure what they are doing. Haven't seen any voice traffic in quite a while as well.
mtindor
OH/WV DB Admin
I realize that without voice comms, you won't necessarily know all the freqs. But can you list all of the active primary/alt control channels shown for Site 19.19 in your Channel Activity window ?
Mike
mtindor
OH/WV DB Admin
If you live near Pharr TX (Hidalgo Co) you might want to check the freqs out on this license . An FCC update (construction requirement filing) was made for this license. This license contains none of the frequencies listed on the Pharr EDACS site. These freqs are all diff.
Could be a clue that a P25 site is online in Pharr or might be in the near future.
Notification: https://wireless2.fcc.gov/UlsApp/ApplicationSearch/applNotificationSum.jsp?applID=11737052
License: WPVQ950 (American Electric Power Service Corporation) FCC Callsign Details -- Location 1
854.1625
854.2375
854.3375
854.4375
854.5625
854.6375
855.0625
855.2875
855.4875
855.6125
855.7375
856.8875
Mike
nd5y
Wichita Falls, TX
In parts of NW Texas and SW Oklahoma AEP can have up to 60 or more channels licensed at some sites that actually only use 4 or 5 channels. I don't know if that is true in other areas.
So far I haven't seen any NWTX/SWOK sites change to P25.
mtindor
OH/WV DB Admin
I noticed the ridiculous number of frequencies on many sites there. Do keep in mind though that they do seem to updating licenses here and there to remove excess. For instance, here is a pending FCC update for Comanche OK (Stephens) :
If you take a look at that, they are removing all but 8 frequencies from that license. One could hope that they might do that for any/all licenses with excessive freqs on them.
mike
RakkFO
Central ohio
I checked up on Etna, Ohio site and found this:
Network: 92715.1F6
Bandplan #0: Base=851. Offset=-45 Spacing=12.5 BW=12.5
Bandplan #8: Base=851. Offset=-45 Spacing=12.5 BW=12.5 Slots=2
Site: 33.33 NAC=021
Neighbor: 92715.1F6-35.35
Neighbor: 92715.1F6-43.43
Neighbor: 92715.1F6-46.46
Neighbor: 92715.1F6-47.47
Neighbor: 92715.1F6-66.66
Channel 0-331: 855.1375 CC
Site: 35.35
Channel 0-241: 854.0125 CC
Site: 43.43
Channel 0-275: 854.4375 CC
Site: 46.46
Channel 0-297: 854.7125 CC
Site: 47.47
Channel 0-281: 854.5125 CC
Site: 66.66
Channel 0-353: 855.4125 CC
mtindor
OH/WV DB Admin
Network: 92715.1F6
Site: 33.33 NAC=021
Site: 35.35
Site: 43.43
Site: 46.46
Site: 47.47
Site: 66.66
What's the RFSS / Site and CC frequency for the site you just checked? I see the neighbors and their freqs, but I don't see a mention of the frequency that you actually picked up the P25 control channel on or a mention of the RFSS-Site.
Mike
RakkFO
Central ohio
Ok, maybe I see it - are you saying Etna is 1F6-33.33 with CC of 855.1375 ?
Correct, here is the event log as well. You are quick on the reply!
2019/10/02 01:00:21 Current site: 33.33
2019/10/02 01:00:21 Current network: 92715.1F6
2019/10/02 01:00:22 Current site: 92715.1F6-33.33
2019/10/02 01:00:22 92715.1F6-33.33 neighbor: Site 92715.1F6-35.35; CC=0-241 854.0125
2019/10/02 01:00:22 92715.1F6-33.33 neighbor: Site 92715.1F6-43.43; CC=0-275 854.4375
2019/10/02 01:00:23 92715.1F6-33.33 neighbor: Site 92715.1F6-46.46; CC=0-297 854.7125
2019/10/02 01:00:23 92715.1F6-33.33 neighbor: Site 92715.1F6-47.47; CC=0-281 854.5125
2019/10/02 01:00:23 92715.1F6-33.33 neighbor: Site 92715.1F6-66.66; CC=0-353 855.4125
