Amite County
milf
Careful, I CAN hear you!
Indianapolis, IN
#2
OK, I think I'm getting enough info on some new talkgroups that I can put this out for people to check.
30401 S.O.
30412 Liberty PD
30416 Unknown fire (possibly Liberty)
Most likely County EOC dispatch for all VFDs... Most of the rural counties do it this way. One dispatch for all EMA/EMS/VFD and then Tac/FGs for each FD.
milf
Indianapolis, IN
#4
Hint: If that Fire/EMA dispatch IDs as Liberty Base,... Its the EOC.
Sheriff IDs as SO Liberty. Or at least that is how they used to do it.
