Analog Radio Identifiers
dimab
CT
Is there a way to receive the radio identifiers with a scanner? For example, my town uses analog motorola hardware. Their dispatch consoles get radio identifiers for all radios. Can these be captured with a scanner? Does it require a discriminator tap and some software?
I'm not sure I'm googling my question correctly so I haven't found any obvious results.
W8RMH
Feed Provider Since 2012
The newer Uniden scanners have this feature (the BCT15X and newer that is).
I include Radio IDs on my feed and a Radio ID Structure Chart on my feed info page.
dimab
CT
Can you explain? I'm aware uniden does it for trunked systems, but not for analog radio units.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Uniden only does it for analog trunking. It does not do it for conventional analog.
If they're using MDC (burst at the beginning and or me of transmission) than you can use the software already mentioned.
D
DaveNF2G
Guest
There is an iPhone app called RadioID that can decode several formats. All you have to do is put your phone where it can hear the scanner's speaker audio. You can also use a wire connection, but I've used it without one and it works fine.
