Digital Box
Hi. I know I have seen a device that you can use plug your older analog radios and convert them to digital. Does anyone have knowledge of this? If so can you recommend a good one?
I believe you are referring to the AOR AR300
Here is the link
ARD300 | OTHER PRODUCTS | AOR,LTD. Authority On Radio Communications
Looking at the Site, AOR are not showing any firmware updates for it at all, and considering the number they issued for the AR-DV1 that is strange.
There are some references to upgraded firmware, but I cannot find any links.
Essentially it appears to be similar in specs to the original AR-DV1, re Digital Modes, and was released at about the same time.
It is not cheap either, you might feel it is not worth the investment as 'new' it is not that much cheaper than an AR-DV1.
If anyone reading this has any knowledge of firmware updates for the AR300, please post the details here.
