Another 396XT - FreeScan question
ham54guy
I'm sure this is a PICNIC (problem in chair, not in computer) problem.
Windows Vista
BCD 396XT
Latest version of FreeScan
Trying to load and assign a quick key for Shawnee, KS PD. I import the Johnson County APCO 25 700 system, uncheck all entities then check Shawnee . Upload to computer.
Two things happen. 1) all preprogrammed systems (QK 21-46) are activated. 2) The entire Johnson Couty P25 system is scanned, but only Shawnee has a name tag.
What am I doing wrong.
Larry
I
captclint
Mountaintop, PA
When you uploaded to scanner, you had the box "send system quick key status" That enable all of them. What a pain..done that more than once. You will have to disable all 25. Not sure about second issue. Maybe you did NOT have the "replace existing sys with same name" checked. If not, then you can read the systems in the scanner and delete a duplicate. Actutally, I would delete both(if you have 2 with same name) and reload it. I have no idea if that is the problem, but it is worth a try.
ham54guy
Thank you! That took care of the first problem. I did have the Replace box checked.
