According to the manual the IF Out has a +/- 5MHz bandwidth, for a total of 10MHz. When I connect the IF Out to an SDR, the signal out is only as wide as the bandwidth setting on the radio. For example, if I tune the AR-ONE to a broadcast FM signal and set the bandwidth to 200k or 300k, that amount of bandwidth is all I see on the SDR spectrum. So, I'm curious - how do I get the full 10MHz out? What I expected to see is all the signals +/- 5MHz of the frequency tuned on the AR-ONE. I've tried multiple different SDRs and SDR software, just to see if it is something I'm doing wrong, but all give the same results. I've also tried multiple different modes and bandwidth settings with the same results.
My main intended use case for the IF Out is to connect it to my AOR AR-DV10 for digital voice decoding, which works fine. However, it would be nice to see (and be able to tune) all that bandwidth and all those signals.
Any ideas would be appreciated, even if they start with...hey dummy, you're supposed to...
73 - David, AG4F
73 - David, AG4F
